Activity › Forums › Apple Final Cut Pro › Deinterlacing in FCPX – video tutorial
Posted by Craig Seeman on September 19, 2011 at 1:44 amI found this tutorial on YouTube for using deinterlacing in FCPX.
https://www.youtube.com/watch?v=FlpyfDntxnc&hd=1
He seems to have a number of FCPX tutorials.
https://www.youtube.com/user/fxmah#g/c/D9CD6F3670992FF7Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Rafael Amador replied 15 years ago 4 Members · 8 Replies -
Dave Gage
September 19, 2011 at 3:25 amHe said the proper setting for that clip would be “lower first”. Any idea why he would say that? Both upper and lower choices seemed to work.
I’m trying to shoot everything these days in 30p as it’s all going to the web, so it may be moot, but it’s nice to know this option is there.
Dave -
Craig Seeman
September 19, 2011 at 3:36 amHDV interlaced is upper but it’s not clear how the deinterlace is working.
If it’s throwing out one field the upper / lower indicator may mean which field is being preserved . . . if it’s throwing out a field. -
Dave Gage
September 19, 2011 at 4:10 amCraig,
Any thoughts on which of the two methods he described would be preferred? He did say the “effect” approach on the Video tab would be a better choice for slow motion effects.
Dave -
Tom Wolsky
September 19, 2011 at 6:24 amNot seeing how changing the field order will deinterlace the video. It will only reverse the field order. I am also seeing progressive having the effect of deinterlacing the the image, which is what I would expect. Or perhaps I completely misunderstood him.
All the best,
Tom
Class on Demand DVDs “Complete Training for FCP7,” “Basic Training for FCS” and “Final Cut Express Made Easy”
Coming in 2011 “Complete Training for FCPX” from Class on Demand
“Final Cut Pro X for iMovie and Final Cut Express Users” from Focal Press -
Craig Seeman
September 19, 2011 at 2:42 pmMy guess is that the function isn’t so much switching the field order (field dominance) but duplicating one or the other field. Hence it appears to deinterlace since there is no motion between two upper or two lower fields. Just a guess of course because this is yet another example of missing documentation in what is very incomplete docs to which Apple has not yet made an “official” PDF of.
Rafael Amador
September 19, 2011 at 3:23 pmIn the first tab (General View) he is just interpreting the footage.
No really de-interlacin nothing.
There is an option to interpret Alpha also.
Same than in FCP Browser.In the De-interlace filter there are to option for duplicating lines (lower/Upper) and one for blending.
In most cases this would be the best option.
Better than the default FCP de-interlace.I haven’t tried FCPX with any interlaced stuff, but I expect FCPX to manage automatically field order issues.
FCPX is designed for modern codec properly flagged on Field Order.
I guess FCPX will de-interlace the footage when dropped to a Progressive sequence.
I guess will shift-fields when needed.
Things to check.
rafael -
Craig Seeman
September 19, 2011 at 3:26 pmAs someone who spends a lot of time dealing with compression apps, de-interlace is not a simple thing. Things like motion compensation and edge detection can come into play. Blending or duplicating fields often yields poor results. This is why it’s important to know what FCPX is doing intrinsically so we can look for other options when optimal results are needed.
Rafael Amador
September 19, 2011 at 4:14 pmSure.
Compressor has a “Motion Compensation” option for de-interlacing, but without much control, and a “Motion Compensation” filter without Motion Masks is a waist of time and and unnecessary picture processing.
I think that as default options Duplicating Fields and Blending are OK.
I expect Re_Vision FieldsKit and Nattress like filters available for FCPX.[Craig Seeman] “This is why it’s important to know what FCPX is doing intrinsically “
Shouldn’t be much difficult to Shouldn’t be much difficult to check if FCPX is duplicating or interpolating lines.BTW, the guy of the tutorial probably chose the worst example he could have done for checking field order.
Hummingbirds flies back and forward and backward and the wings moves to fast to see iwhere are they going. Impossible to know by eye is is upper or lower. But is HDV.
rafael
