Activity Forums Adobe After Effects Deinterlacing concerts with fast blinking is problematic
  • Deinterlacing concerts with fast blinking is problematic
    Posted by Anders Haavie on November 28, 2005 at 8:47 pm
    Anyone tried deinterlaced concerts that has flashing lights ? The deinterlacing messes up and you end up getting bit black areas in the picture. Anyone have a fast fix for that ?? What numbers should I change ? Guess it is the big differences in the picture that messes things up.
    My preset is (dv-pal)
    fields Blend 1 frame per frame
    field order (lower)
    fill method Blend
    detect motion 3 frames compare
    detect method small area
    motion tolerance 0,3
    mask supress 1
    mask grow 3
    mask feather 3
    smooth vertically 0
    sharpen 0
    Anders
    Anders Haavie replied 20 years, 9 months ago 2 Members · 2 Replies
  • Pierre Jasmin
    November 28, 2005 at 11:28 pm
    Send techsupport@revisionfx.com a few frames (like 5) where you see that effect. In most applications the menu is animatable, if the Motion Compare screws up on flashes.
    Pierre
  • Anders Haavie
    November 29, 2005 at 8:01 pm
    Will do, just when this 30 hours rendering time is finished in AE (is it faster in FCP than AE on my 2×2 dual g5 ?)
    Anders
