Activity Forums VEGAS Pro Deinterlacing
  • Deinterlacing
    Posted by Fred Williams on April 15, 2009 at 6:23 pm
    Good Morning.
    I thought I had this figured out, and then I came across a post in this forum that has confused me once again. I shot a clip in 24P using a Canon HV30. It came out great and life was good until the deinterlacing subject came up. In a post here, someone mentioned that Canon doesn’t put flags in the movie that Sony can see so the de-interlacing is not performed and I will need another program to do that for me. Questions
    1. To play on a computer, do I need to even do this? (deinterlacing)
    2. Is other software exempt from this problem
    3. Where would one find this program if Sony Vegas movie studio Platium can’t do it. ?
    Thank you for any help.
    Fred Williams replied 17 years, 4 months ago 2 Members · 2 Replies
  • Eric Manacsa
    April 17, 2009 at 9:46 pm
    Check out Cineform Neoscene. It will capture your HV30 PF24 files as you expect them as.
  • Fred Williams
    April 22, 2009 at 11:28 am
    Thank you. I did download the Demo, and it looks like it is what you need to get a true 24P at least from the HV20/30 I undertsand that the HV40 handles a true 24P. Wish they would come out with a firmware fix, but they (Canon) stand by thier stance that it should be the NLE companies since they just did a workaround with the HV20 HV30 to make 24P available. Oh well, it is what it is.
    Again, Thanks for the advice.
    Have a good day
