Activity Forums Media 100 deinterlacing
  • deinterlacing
    Posted by Jason Rogerson on November 7, 2008 at 2:45 pm
    I’ve been trying to export a quicktime file from Media 100 HDe (version 12.1.3 Intel – using it in an SD configuration) as deinterlaced but no matter what I try, it seems to always appear to be interlaced. I’ve tried clicking deinterlace source video, setting the field dominance to progressive – nothing seems to give me deinterlaced results. Is there something I’m missing? Any advice welcome.
    Dennis Dean replied 17 years, 9 months ago 5 Members · 6 Replies
  • Olof Ekbergh
    November 7, 2008 at 6:48 pm
    I always use AE to deinterlace. Results are great.
    Olof Ekbergh
  • Jason Rogerson
    November 7, 2008 at 7:22 pm
    Do you do that using Reduce Interlace Flicker under the Blur and Sharpen menu or is that something you click when you’re within the Make Movie settings?
  • Chris Clephane
    November 8, 2008 at 4:21 am
    To get the desired deinterlaced video….in AE you render your movie WITHOUT fields selected.
    RENDER QUEUE : RENDER SETTINGS : FIELD RENDER (OFF)
    Render to a CODEC that works without interlacing. (ie..ANIMATION)
    Good luck.
    I edit video. I post sometimes.
    I fix things. I eat marshmallows.
    I play drums. I drink scotch.
    I like TV.
    Done typing now.
  • Dennis Dean
    November 12, 2008 at 7:17 pm
    Here’s a trick I use in Final Cut – Don’t know if it will apply to your application but the instructions are generic enough that they might.
    Highlight the clip you want to deinterlace.
    Duplicate it and place on a second video track
    Set clip opacity to 50%
    Apply the deinterlace filter to V1 with the LOWER setting selected
    Apply the deinterlace filter to V2 with the UPPER setting selected.
    Render and export as needed.
    Gives me very good results.
    Dennis Dean
    The Dean Group
    -It’s about results-
    http://www.deangroup.com
  • Fabrizio Lazzeretti
    November 22, 2008 at 4:15 pm
    Thank you Dennis,
    i was looking for some technique and yours seems to be the best without need of plugin use.
    Cheers.
    Fabrizio
  • Dennis Dean
    November 22, 2008 at 11:10 pm
    Glad I could help – but the credit goes to someone over the Final Cut forum – which is where I found this. Nice when forums can reach across the aisle (as it were) to get something done.
    Dennis Dean
    The Dean Group
