Activity › Forums › Adobe After Effects › deinterlace with scanlines – PAL
  • deinterlace with scanlines – PAL
    Posted by Sylvain Bégot on January 23, 2009 at 10:11 am
    Does anyone know how to create (or download somewhere) a “scanlines” PSD file in order to deinterlace PAL video ? (4/3 + 16/9 would be very welcome). I actually have a NTSC one but I don’t think I can use it with PAL footage.
    Thanks.
    Cathy Goddard replied 13 years, 5 months ago 4 Members · 7 Replies
  • 7 Replies
  • Chris Wright
    January 23, 2009 at 10:23 pm
    It’s updated to have PAL and HDV PSD too. File in project is called PAL DV scanlines. Click download project files.
    https://www.videocopilot.net/tutorials/deinterlace_in_ae/
  • David Keslick
    January 23, 2009 at 10:30 pm
    I am a little unclear about the scanline PSD. However, if you are looking to deinterlace you footage you may want to check out DVFilm Maker. It can deinterlace NTSC, PAL, 4/3, or 16/9.
    Hope this helps.
    Dave Keslick
    DVFilm.com
  • Chris Wright
    January 23, 2009 at 11:59 pm
    I directly compared the PSD method to just fields off AE export. AE is way, way better anyway; even more so plugins that are designed for this: dvfilm, fieldskit, magic bullet, algolith etc. Heck, even virtualdub probably looks better. People have used timewarp vectoring to merge the two fields together too.
  • Sylvain Bégot
    January 24, 2009 at 10:15 am
    Thank you Chris!
  • Sylvain Bégot
    January 24, 2009 at 10:18 am
    Thanks for the tip. But I actually tried different ways to deinterlace and I think the “scanlines.psd” method is the best, since it’s the one on which you get the most control.
  • Sylvain Bégot
    January 24, 2009 at 10:24 am
    Hi Dave,
    Well, speaking of my case, I have noticed that most of my viewers (since I am an editor and DVD authorer in the education field) are watching our products on their computers. That’s why I started to deinterlace the video, using what I call the “scanlines.psd” method in order to keep a good control and reduce the old-tv-screen flickering as much as I can.
  • Cathy Goddard
    April 2, 2013 at 3:33 pm
    Sylvain, I see that this post is pretty old, however, do you still have the ntsc .psd scanlines document that you might wish to share?
