Activity Forums Apple Final Cut Pro Legacy Deinterlace plug
  • Deinterlace plug
    Posted by Tom Brooks on August 7, 2007 at 2:42 am
    I need to deinterlace some 60i DV footage to intersperse with some 30P (Yes, THE 30P.) material in a Ken Burns-ish history program. Any recommendations on a really good, fast (motion-compensated?) deinterlacer that I could just drop in as an effect and take care of the 60i bits (without dropping another 1000 clams). Fieldskit looks like a good package. Nattress Film Effects has deinterlacers and other goodies. Your ideas? Thx.
    Ed Dooley replied 19 years, 1 month ago 8 Members · 10 Replies
  • 10 Replies
  • Rafael Amador
    August 7, 2007 at 3:47 am
    Tom,
    The two of them are really good. Fieldskit is mor specific about interlacing (it got de-interlacer, pull down remover and re-interlacer) and give you some options that you don’t get with Nattress (like making a ful Frame from each field). The Nattress is great and come with many interesting things in the same package.
    You can make a try as well with “Smart de-interlace” of TooMuchTooSoon. Is free. Works very well if you set the “Motion sensitiviti” to the top.
    Cheers,
    Rafael
  • Jeremy Garchow
    August 7, 2007 at 3:55 am
    Rafael has some good suggestions, and I have one that is expensive. Boris Continuum Complete has pretty nice deinterlacer, but if you buy it just for that, it might not be worth it. BCC is a pretty good suite of effects. I use it a lot for Green Screen within FCP.
    Jeremy
  • Anders Haavie
    August 7, 2007 at 7:03 am
    RevisionFX is great. I use it alot. However it’s quite slow. I find it faster in AE than FCP. Nattress is supposed to be good as well.
    Anders
  • Chris Poisson
    August 7, 2007 at 1:44 pm
    FieldsKit is exactly what you want, it’s as good as or better than any other. Plus it works in FCP and AE. Fantastic control.
  • Tom Brooks
    August 7, 2007 at 2:20 pm
    Thanks very much!
  • Ed Dooley
    August 7, 2007 at 3:23 pm
    And one more: Do a search here for it in this forum. Compression does a great job
    (without just throwing away a field). It’s in the Advanced Format Conversion section.
    Ed
  • Tom Brooks
    August 7, 2007 at 5:10 pm
    Ed,
    Yep, I have used that function with good results. I’ll have to weigh the advantages of a batch conversion of clips as opposed to a plug-in approach. I guess it comes down to which one saves the most time and quality and if it’s a tossup, the free one wins. Thanks.
    -Tom
  • Camshaft
    August 7, 2007 at 7:37 pm
    What are people’s thoughts on FCP’s de-interlacer? I have used it on DV and it “appears” to work very well. When going for a look is when I’ve used Nattress Film FX, and the included de-interlacing. Both of these options are loads cheaper than Boris.
    Cameron Young
  • Graeme Nattress
    August 7, 2007 at 8:30 pm
    If you have FCP6 you can try the one that I do in Color too, which is smarter than the smart ones I have for FCP in Film Effects.
    Graeme
    http://www.nattress.com – Film Effects and Standards Conversion for FCP
  • Ed Dooley
    August 7, 2007 at 10:39 pm
    The built-in de-interlacer throws away information. I wouldn’t recommend it when there are other (even free) options.
    Ed
    [camshaft] “What are people’s thoughts on FCP’s de-interlacer? I have used it on DV and it “appears” to work very well. When going for a look is when I’ve used Nattress Film FX, and the included de-interlacing. Both of these options are loads cheaper than Boris.”
