Activity › Forums › VEGAS Pro › Deinterlace method? Opinions?
  • Deinterlace method? Opinions?
    Posted by Brad Leigh on September 28, 2013 at 11:38 pm
    About to do my final render on a long project.
    Expect I will be rendering mp4 720P
    Project is about 50% animations that are progressing footage.
    25% HDV 1440i 25% 1920i hd.
    My camera is always locked down, and not a lot of motion in the shots.
    If I don’t have resample deselected on all regions does that play into deinterlace? or is that only a factor with differing frame rates?
    Any strong opinions of blend vs interpolate? (assuming my case which is very little movement or pans in the frame).
    Brad
    i7 2600 3.4 Ghz 8Gig Ram , Win 7 Pro, Vegas Pro 12
    John Rofrano replied 12 years, 12 months ago 2 Members · 3 Replies
  • John Rofrano
    September 28, 2013 at 11:57 pm
    [Brad Leigh] “If I don’t have resample deselected on all regions does that play into deinterlace? or is that only a factor with differing frame rates?”
    That only affects frame rates.
    [Brad Leigh] “Any strong opinions of blend vs interpolate? (assuming my case which is very little movement or pans in the frame).”
    Blend should always be used unless your motion is so high that Blend can’t remove the interlace artifacts, then you should use Interpolate understanding that it will reduce your vertical resolution by 1/2.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Brad Leigh
    September 29, 2013 at 12:20 am
    John
    Once again a big Thank You!
    Brad
  • John Rofrano
    September 29, 2013 at 11:58 am
