deinterlace dvpal
thanx for reading. maybe you can help me and my project.
i did my first documentary/65min/dvpal/captured with 3 sony cameras minidv 3ccc. this bad, now i know…
the picture quality is not ok. one can see “stairs” in the outlines of the people. and when someone is moving for ex. the hand, one can see horizontal lines. i did a research and now i think, this is because i have interlaced data from 3 cameras. what do you think?
so i started to deinterlace it with fcp. tried different settings. but none of mine was sufficent.
in after effects i used the effect called “reduce flicker” this worked out, but the picture lost sharpness.what would you do with this project? belive me, i would be more than happy, if we could fix this problem.
