Activity Forums DVD Authoring deinterlace and resize mpeg2 stream
  • deinterlace and resize mpeg2 stream
    Posted by Ozben on July 6, 2005 at 1:27 am
    Hi there,
    I have been given a DVD that a client wants me to return in 5 discreet segments to be run on the company intranet. The source material is 720×576 interlaced, but the client wants 520×416 resolution, deinterlaced. Not accustomed to editing mpeg, i have used TMPGEnc to edit the source material into the 5 segments required, but extensive googling has revealed nothing on how I can adjust the resolution and deinterlace. Any idea what program might do this? I’m trying to avoid encoding to avi, then back to mpeg, to avoid generational loss.
    Cheers.
    Ozben replied 21 years, 2 months ago 2 Members · 4 Replies
  • David Roth weiss
    July 6, 2005 at 2:42 am
    Procoder will do it all, I just tried… Perhaps TMPGenc can do it too if you can find a way to force it to create an ISO MPEG Stream (the only absolutely customizable MPEG2 stream).
  • Ozben
    July 6, 2005 at 5:59 am
    Ok I have access to procoder here, but have never used it before. Forgive me for asking here, but there is no procoder forum.
    I can get it to deinterlace, but I can’t find where to adjust resolution. I see a crop function, but that is not an option.
    Have checked the help files, and can find no answers.
    Thanks in advance
  • David Roth weiss
    July 6, 2005 at 8:35 am
    Set the target for DVD, then change the stream format to Generic ISO MPEG Stream — then go down and change the width and height to the appropriate numbers your want.
    Its all there… thats the only way to do it.
  • Ozben
    July 7, 2005 at 4:50 am
    Much appreciated. I hadn’t got that far, i’d assumed i’d adjust resolution at the smae point i applied the de-interlace.
