Activity Forums Apple OS X defragmenting the tiger…
  • defragmenting the tiger…
    Posted by Jeffrey A dear on June 11, 2005 at 9:49 pm
    I realize there’s typically no reason to defragment with OS X. However, when large video files are moved around, deleted, so on and so forth, is there a need to defragment the OS X tiger?
    Jeffrey
    Jeff Carpenter replied 21 years, 3 months ago 2 Members · 1 Reply
  • Jeff Carpenter
    June 12, 2005 at 1:26 am
    You should be putting large files like that on a drive other than your system drive. Sometimes when I can get the drive small enough I copy everything that’s left off of it and re-format it by writting zeros to the entire drive. Then I copy whatever I had left back onto it. Sometimes I’m luckyk enough to get all of my jobs done and can just wipe the whole thing.
    I don’t know if that’s something that has to be done, but it’s fairly simple so I do it just to be safe.
    But in those cases there’s no reason to mess with the system drive itself.
