Activity Forums Avid Media Composer Defragging the video drive
  • Defragging the video drive
    Posted by Doug Collins on December 11, 2006 at 11:46 pm
    What is the consensus on defragging the video drive on an Avid Xpress Pro system? I have recently deleted a bunch of stuff from the drive.
    Doug
    Doug Collins replied 19 years, 9 months ago 3 Members · 3 Replies
  • Jon Zanone
    December 12, 2006 at 12:11 pm
    Don’t.
    The system likes having files broken up. Most of your underrun errors are because files are to close together.
    I’d defrag the C: drive, but never the media drive.
    Jon
  • Jonathan Pitzer
    December 12, 2006 at 1:45 pm
    DO NOT DEFRAG A VIDEO DRIVE. Thi swill cause havoc on your AVID system. The manual says explicitly not to defrag. If you do, your system will not work unless you completely rebuild your database. The Avid software uses a fragmented system on purpose. Especially on a computer with a RAID system. The fragmenterd files can be accesses faster by using that AVID database and that is what allows your system to work without thousands of dollars worth od extra hardware. Once again, DO NOT DEFRAG!
  • Doug Collins
    December 12, 2006 at 4:57 pm
    Thanks!!
    Doug
