Activity › Forums › Maxon Cinema 4D › deforming imported OBJ
Posted by Lavender on January 19, 2007 at 1:58 amtotal newbie looking for a way to deform an imported OBJ derived from a 3D body scan. we want to simulate weight gain/loss as realistically as possible
Can Cinema 4D do this? I’ve had no luck in Poser. I have a demo of C4D 9 and the OBJ opens up OK. I ‘ve never used C4D and would like an idea of my chances of success before committing to the programMany Thanks
Lavender replied 19 years, 8 months ago 2 Members · 7 Replies -
Adam Trachtenberg
January 19, 2007 at 6:11 amIt’s certainly possible. How easy or hard it will be will depend a lot on the quality of your model. 3d scans often result in iffy geometry in terms of having zillions of polygons, awkward triangulation, reversed normals, etc., etc.
There are a few ways you would approach it, or you could use a combination of:
*parametric deformers, such as the bulge, taper, and bend deformers;
*keyframed point-level animation (PLA);
*morphing (requires Mocca or a plugin).
As far as modeling the PLA/morph targets, I would use a lot of the Mesh Brush and the Magnet Tool.
Lavender
January 19, 2007 at 6:33 amThanks Adam,
the scan has been simplified with an overlaid Poser mesh applied via Cyslice. I’ve been able to open it and do a bit of basic manual tweaking. I’ll give your suggestions a go.
Do you know of anyone else trying to do this? Or a tutorial on the tools you suggest? -
Adam Trachtenberg
January 19, 2007 at 5:34 pmOh, Cyslice–cool. 🙂
Hold on a sec, I’ll put together a quick and dirty vid tut for you.
Adam Trachtenberg
January 19, 2007 at 6:58 pmOkay, here’s the promised mini-tut: https://www.3danvil.com/tutorials/FatMorph/fatmorph.html
If you want to download the file you can replace the “.html” with “.swf”.
Lavender
January 20, 2007 at 12:01 amHey Adam,
brilliant!
I can see that this might be just what we want.
Great tutorial – unfortunately I can’t get sound – is there any?
I open up in QuickTime 7 ( Intel iMac – OS 10.4) and the sound track setting keeps defaulting to minus infinity no matter what I do 🙂Cheers
Keith
in AustraliaWenn ich fragen darf, Sind Sie Deutsch? Ich leider nicht, aber ich habe die Sprache gelernt.
Adam Trachtenberg
January 20, 2007 at 4:08 amSorry, it was a silent pic. 🙂 I’d be happy to explain anything that wasn’t clear.
Lavender
January 22, 2007 at 5:20 amVery impressive tute Adam, many thanks.
This could well be what we’re after
However . . . I don’t seem able to replicate your actions on my system. (Mac OS 10.4 CD4 9.012 ( demo as yet). )
When you go to the Tags menu and open Character Tags/ Morph . . . I don’t have that range . I only have CD4, Clothilde, Dynamics, Mocca and Sketch.Also my Attributes panel looks different
Will I need version 10 and specific plugins perhaps?
