Activity Forums Maxon Cinema 4D Deformer problems….suggestions and help needed.
  • Deformer problems….suggestions and help needed.
    Posted by Brett Thayer on October 1, 2008 at 5:37 pm
    I am having some problems trying to get one of my objects to deform like I need it to.
    I have created a chain of joints with control handles to distort the object but I cant get the model data to stay smooth looking and I cant get the object to distort as much an far as i need it to.
    I went this after none of the deformers worked like I needed them to.
    Here is a sample photo sequence of what I’m trying to get done
    https://www.pixelspowerandlight.com/remove.mov
    Here is a sample animation of what I have so far:
    https://www.pixelspowerandlight.com/remove_anim.mov
    I made no attempt to try and stretch the chained portion of the model.
    Here is my model data if you want to see what Ive done.
    https://www.pixelspowerandlight.com/removal animation_final.c4d.zip
    Any help or suggestions will be much appreciated.
    Brett
    Brett Thayer replied 17 years, 11 months ago 1 Member · 0 Replies
  • 0 Replies
