Activity Forums Maxon Cinema 4D Deformer Problem
  • Deformer Problem
    Posted by Dave Edwards on May 16, 2011 at 6:30 pm
    This has to be something really silly but I place a cube, add a deformer such as twist, make the cube the child of twist and move the yellow dot.. the purple “cage” of the deformer moves – twists etc,- .. but nothing happens to the cube.
    Tim Shetz replied 15 years, 4 months ago 2 Members · 3 Replies
  • Tim Shetz
    May 16, 2011 at 9:23 pm
    Deformers work differently than NURBS. The deformer must be a child of the object or in a null, a sibling TO the object you wish to deform. You also need to make sure the primitive you are using has enough geometry to be deformed properly.
    Hope that helps.
    Tim
    __________
    Tim Shetz
    c4dtraining.com
  • Dave Edwards
    May 17, 2011 at 6:26 am
    Hi Tim,
    Thanks very much,- problem solved. I did take a look at the in-built help but managed to miss this..
    DE
  • Tim Shetz
    May 17, 2011 at 3:43 pm
    Glad you got it to work.
    There is SO much to read in the help, I know it is easy to miss things once in a while.
    Tim
    __________
    Tim Shetz
    c4dtraining.com
