Activity Forums DaVinci Resolve Deflicker slowmo footage
  • Deflicker slowmo footage
    Posted by Felix Gorbach on July 31, 2013 at 8:46 pm
    Dear DaVinci Gurus,
    Made a few Redclips with different fps – from 100 to 300fps – they look realy great – and it´s asthonishing what you can get out from the footage with DaVinci. I´m impressed.
    Shot the footage in Europe in a small studio – and yes – what I expected happend – From the lights I have of corse a lot of flickering. Is there a way to get around this issue in DaVinci – or should I use some after Effects Plugin after grading? Do you have any suggestions for a workflow for this issue?
    Thanks a lot and best wishes,
    Felix
    Felix Gorbach replied 13 years, 1 month ago 2 Members · 2 Replies
  • Dmitry Kitsov
    July 31, 2013 at 11:05 pm
    Boris has something for deflickering, haven’t used it though.
  • Felix Gorbach
    August 1, 2013 at 5:48 pm
    Hy Dimity,
    Thanks for the tip. It works with BCC Flicker Fixer – new in suite8 – it has some adjustments that allows to finetune to the result I needed. So anyway, I would give definitely a try to bcc.
    thanks,
    Felix
