Activity › Forums › RE:Vision Effects › DE:Flicker creates artifacts around stars
  • Pierre Jasmin
    October 26, 2015 at 12:21 am
    Two things to try:
    1) Constant Color Fix [ X ]
    2) Set Max Color Change to 0% (as this is primarly monochrome)
    Pierre
  • Leandro Pérez
    October 26, 2015 at 12:36 am
    Setting Max Color Change to 0% did not affect very much the results.
    Enabling Constant Color Fix fixed the issue, but it also introduced some nasty artifacts as well: https://i.imgur.com/P9gdUMu.jpg
    I don’t know if it helps, I’m working on a 16 pbc project with the Cineform codec.
    View post on imgur.com
  • Pierre Jasmin
    October 26, 2015 at 1:44 am
    OK
    Feel free to hit https://revisionfx.com/support/contact/
    Which will send upload video info
    If you want tech support as well
    Also without Constant Fix on – try Method 2
