Activity › Forums › Adobe Premiere Pro › default transition
default transition
Posted by Bruce Wertovitch on October 21, 2011 at 3:21 pmHow do I apply the default transitions between multiple contiguous pictures at the same time on the same track in Premiere Elements 7?
Thanks, BruceBruce Wertovitch
Kevin Monahan replied 14 years, 11 months ago 4 Members · 10 Replies -
Ann Bens
October 21, 2011 at 7:26 pmHave no idea, but try, select track first, Page up or down followed by Ctrl+D for video and Ctrl+Shift+D.
Adobe Certified Expert Premiere Pro -
Kevin Monahan
October 24, 2011 at 6:10 pmUsually I do that before adding clips to the timeline with Automate to Sequence: https://help.adobe.com/en_US/premierepro/cs/using/WS1c9bc5c2e465a58a91cf0b1038518aef7-7d1ba.html
Kevin Monahan
Sr. Content and Community Lead
Adobe After Effects
Adobe Premiere Pro
Adobe Systems, Inc.
Follow Me on Twitter! -
Ann Bens
October 24, 2011 at 8:37 pmKevin this is Elements.
Bruce Wertovitch
October 24, 2011 at 9:56 pmThere must be a simple way to add the same transition to multiple pictures in Adobe Premiere Elements 7, no?
Ann Bens
October 25, 2011 at 6:55 pmCheck the manual.
Jeff Walsh
October 25, 2011 at 8:51 pmHi Bruce,
Select all the clips from the sequence that you want to apply the transition (assuming that it’s the same transition that you want to apply) and hit command>T or select Sequence from the menu>Apply default transition. You can change the default by right clicking a transition in the effects bin and choosing>Make default transition.
Bruce Wertovitch
October 25, 2011 at 9:26 pmSounds like you have the solution…but I’m not familiar with “command>T” or how to find/select “Sequence” from the menu. I looked in all the drop-down menus along the top tool bar and don’t see them there. Sorry to be a nuisance, but could you give me some more detail on how to find those?
Thank you!!
Ann Bens
October 25, 2011 at 9:49 pmPeople think you are on Premiere Pro instead of Premiere ELEMENTS 7
Jeff Walsh
October 25, 2011 at 9:53 pmSorry Bruce, I should preface this by saying I’m using APP 5.5 with a FCP keyboard command set from the keyboard layout. That and I use a Mac so that might account for some differences. That said, I can’t say why you don’t have ‘sequence’ as a menu item on your menu bar. You might try Control>D if you’re a PC user after highlighting adjoining clips. Also be sure that these clips have handles.
Kevin Monahan
October 27, 2011 at 6:40 pmSorry, there are no Premiere Elements forums here on the Cow. Here’s a link to the Adobe forum for Elements: https://forums.adobe.com/community/premiere_elements?view=all
Kevin Monahan
Adobe After Effects
Adobe Premiere Pro
Adobe Systems, Inc.
