Activity › Forums › Apple Final Cut Pro › Default transition duration
  • Bret Williams
    August 7, 2019 at 7:15 pm
    Enter .67 as the duration.
    ______________________________________________________
    https://BretFX.com FCPX Plugins & Templates
    New Transition Pack! SLIDE WIPES Customizable Wipes that Move
    https://bretfx.com/product/slide-wipes
  • Bret Williams
    August 7, 2019 at 7:17 pm
    That would be for a 30fps project to get a 20 frame duration. It’s not listed in frames because 20 frames for a 30 fps project wouldn’t be the same duration as 20 frames for a 24p or 60p project. So it’s in seconds.
  • Greg Ball
    August 7, 2019 at 8:14 pm
    Thanks Bret! That really is terrible! There should be frame durations instead of seconds. I’ve been editing for 25 years and never saw where I would have to set a duration preference at 67.
    Greg Ball, President
    Ball Media Innovations, Inc.
    https://www.ballmediainnovations.com
  • Bret Williams
    August 7, 2019 at 8:19 pm
    It’s actually smart.
    When you say you want a 15 frame dissolve, what do you really mean? You mean a half a second. So if 15 frames were the default, you’d get different length dissolves in all your different frame rate projects. You’d get 1/4 sec in a 60p, 1/2 sec in a 30p, and 62/100 a sec in 24p.
  • Eric Santiago
    August 7, 2019 at 10:46 pm
    They should have named presets.
    Example, Bruckheimer, Malick, and the ever so popular Lucas 😉
  • Greg Ball
    August 7, 2019 at 11:34 pm
    Actually even FCP 7 allowed you to choose the exact frame rate for an effect. That worked fine.
    Bret do you think you can answer this question. You seem to be the only one on this forum.
    I’m doing a multicam project. All along on the first 7 projects, I’ve been able to to cut to a camera angle then if needed, watch all of the angles in the viewer and just drag the cut point a few frames to make sure I don’t see a bump of the camera. I’m working on the next project and for some reason when I try to drag a few frames one way or the other, I lose sight of the 3 camera angles, so I can’t get a precise edit. If I go back to a previous project it all works fine.
    Nothing has changed. Did I inadvertently click on something? This is very weird. Not helpful for a 90 minute video with many cuts.
  • Bret Williams
    August 7, 2019 at 11:55 pm
    I saw that post and I don’t know the answer right off the bat. And I don’t have a multi-cam project recently to test. Can you post a screen recording or grab? Might help. I’m assuming you have the angle viewer open and all that.
  • Greg Ball
    August 8, 2019 at 5:35 pm
    Hi Bret,
    Here’s a screen capture. Hope this works
    13628_fcpxdemo.mov.zip
