Activity Forums VEGAS Pro Default settings?
  • Default settings?
    Posted by Morten Friis on April 11, 2006 at 1:24 pm
    Let me admit… am not so familiar with Vegas, but I have some wishes for default settings:
    In ‘pan and crop’ I always(98%) put the ‘smoothnes’ to zero, because that works best with the stuff I’m doing.
    And because I use a lot of still-pictures I always check/mark the “reduce interlace flicker” in properties.
    Could these settings, and others who are not obviously seen in preferences, be made default. (if that’s the way to say it – not my mothers tongue)
    … and thanks for a perfect and vivid forum. Morten
    Copenhagen
    Stephen Mann replied 20 years, 5 months ago 8 Members · 12 Replies
  • 12 Replies
  • Edward Troxel
    April 11, 2006 at 3:40 pm
    [mfriisn] “Could these settings, and others who are not obviously seen in preferences, be made default. (if that’s the way to say it – not my mothers tongue)”
    For photos, I animate them automatically using the Video Scrapbook tool in Excalibur which can also turn on the “Reduce Interlace Flicker” flag. It also has a tool to reset all keyframes to “zero” smoothness.
    I know of no way of making them the “default” values, though.
    Edward Troxel
    JETDV Scripts
  • Jeremy Rochefort
    April 11, 2006 at 4:30 pm
    There are many reasons for not making certain settings “defaultable” in Vegas.
    Adjust your workflow to accomodate these items and one way would be to write a small script to do this functionality for you when required or alternatively, use one of the great many add-ons to Vegas like Excalibur. I would probably be taking ten times longer if it were not for the automation it provides.
    Jeremy
    MJ Productions
    MJ Productions
  • Anotheruser
    April 11, 2006 at 4:33 pm
    Can you guys let me know about any other must-have plugins i should consider?
  • Jeremy Rochefort
    April 11, 2006 at 6:39 pm
    If you are going to run with Excalibur, I’d try and master its many features first. This will probably help you a long way into the editing workflow and getting to know Vegas pretty good.
    Jeremy
    MJ Productions
    MJ Productions
  • Anotheruser
    April 11, 2006 at 8:15 pm
    Great.. dumb question.. but.. where do I get Excalibur ? 🙂
  • Edward Troxel
    April 11, 2006 at 8:18 pm
  • Jeremy Rochefort
    April 11, 2006 at 8:28 pm
    Yeah well – sometimes we forget the obvious and make the same mistake we all tend to make too often sometimes – WE ASSUME.
    Thanks Edward
    Jeremy
    MJ Productions
    MJ Productions
  • Terry Esslinger
    April 11, 2006 at 9:08 pm
    Lets not forget Ultimate S. I use both Excaliber and US and find them both very useful (with a little bit of overlap)
  • Wayne Starick
    April 11, 2006 at 11:03 pm
    Quote:
    ” Lets not forget Ultimate S. I use both Excaliber and US and find them both very useful (with a little bit of overlap)”
    I have both tools as well and agree with Terry.
    Wayne Starick
    If there is no Internet in heaven – I am not going!
  • Rob James
    April 12, 2006 at 12:00 am
    While we’re on the subject, I’d have to say that, 3D plugin Pak and SpiceMaster are indispensable tools for Vegas! 3D being free and SpiceMaster a bit pricey, but well worth the investment.
