Activity Forums Adobe After Effects default render settings
  • default render settings
    Posted by Dustin Ward on June 6, 2010 at 2:29 am
    The default for AE renders is “Animation” with no alpha channel. Is there a way to change the default to have an alpha channel?.. even if I have to modify the script.
    Todd Kopriva replied 16 years, 3 months ago 2 Members · 1 Reply
  • Todd Kopriva
    June 6, 2010 at 4:11 am
    from “Change output module settings”:
    “Note: The default output module settings template is assigned to a render item when it is created. To change which output module template is the default, hold down Ctrl (Windows) or Command (Mac OS) as you choose an output module template from the menu.”
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
    If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share—or if there is something that you’d like to see added or improved—please leave a comment.
