Activity › Forums › Adobe After Effects › default project settings
  • default project settings
    Posted by Anders Bundgaard on June 26, 2013 at 9:32 pm
    hello all,
    is it possible to change the default project settings so when i make a new project it will always be, for example, 32bit with a srgb profile?
    thanks in advance
    anders
    John Cuevas replied 13 years, 2 months ago 3 Members · 5 Replies
  • Todd Kopriva
    June 26, 2013 at 9:50 pm
    Create a template project.
    After Effects team blog
  • Anders Bundgaard
    June 26, 2013 at 9:52 pm
    project template as in using that everytime i need a new project or is there a way of making it the default settings when i make a new project?
  • Todd Kopriva
    June 26, 2013 at 9:58 pm
    Make a template project that has the settings that you need. Open that each time you need to start a new project. Be sure to read the page that I linked to so that you understand what a template project is.
  • Anders Bundgaard
    June 26, 2013 at 10:00 pm
    thanks.
  • John Cuevas
    June 27, 2013 at 12:01 am
    Load Project or Template at Startup
    Will launch a project or template every time your start After Effects. For example, if you have a certain folder/file structure you like to keep for your AE projects, you can setup a virgin project the way you like it and save it as a template by giving it a .aet extension. Now every time you launch AE your custom setup will be automatically loaded.
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
