Activity › Forums › AJA Video Systems › Default Number of Audio Channels
  • Default Number of Audio Channels
    Posted by Brian Leighty on April 22, 2009 at 7:14 pm
    I have a Mac Pro running FCS2 with a LHe Kona capture card. It always defaults to capturing 8 channels of audio when I 99% of the time only need one or two. Does anybody know anyway to make it not default to 8 channels? I have already tried messing with the preset and the only two options I have are 8 channel 16bit and 8 channel 24 bit. Thanks.
    Matt Larson replied 17 years, 5 months ago 3 Members · 2 Replies
  • Doug Beal
    April 23, 2009 at 9:26 pm
    I turn off what I don’t need in my L&C window. Next time I go back in ,unless I am using an easy setup I haven’t used befor or I have updated some part of FCP, or trashed prefs it remembers what I selected last time I used it. Kona 3 ver6.0.3
    Doug Beal
    Editor / Engineer
    Rock Creative Images
    Nashville TN
  • Matt Larson
    April 24, 2009 at 6:49 pm
    I do it through the browser: Typically when I capture, I log all the clips on the tape and then do a batch. Before I do a batch capture though, I select all the clips in the browser that I have logged and right-click. One of the options in the menu is Clip Settings (or something like that). If you select that, you can set all of your clips to have less than 16 channels of audio.
    2 x3Ghz Quad MacPro
    9 GB RAM
    Mac OS X 10.5.5
    QT 7.5.5
    FCP 6.0.5
    AJA Kona 3 (6.0.1 drivers)
    G-Speed XL 12 RAID
