Activity Forums Maxon Cinema 4D Default light
  • Default light
    Posted by Andy Proud on August 10, 2016 at 9:32 am
    Hi, when I try to make something in C4D there is always turned some light on, so I wanna ask whether I can adjust the brightness of this light, because it’s very intense. Thanks!
    Andy Proud replied 10 years, 1 month ago 2 Members · 2 Replies
  • Adam Trachtenberg
    August 10, 2016 at 1:40 pm
    If you go into Render Settings>Options you can adjust the global brightness.
    Also, if you create your own lights and use gouraud shading you won’t see the default lighting.
    Having said that, the default light shouldn’t be overwhelming by default. You might need to adjust your monitor.
  • Andy Proud
    August 11, 2016 at 7:47 am
    Everything you wrote helped me. Thanks man!
