Activity › Forums › Apple Final Cut Pro Legacy › default in/out frame length, shortcut
  • default in/out frame length, shortcut
    Posted by Adam Chesbrough on March 29, 2011 at 4:07 pm
    I am creating a music video on a 24 fps timeline and want to grab 12 frame cuts from hundreds of different clips, is there a fast way to go about doing this. I would be fine with opening the clips, entering the in point and being able to forgo “+12, enter , O, F12” step.
    Is there a way to copy clip length in the timeline and paste it to other clips within the timeline? There is nothing within the “paste attributes” that accomplishes this. I appreciate any help/ideas.
    macbook pro 17″ i7, 8GB RAM
    2 RAID 0 esata external HD 7200RPM
    Adam Chesbrough replied 15 years, 6 months ago 2 Members · 2 Replies
  • Patrice Freymond
    March 29, 2011 at 5:00 pm
    Don’t know of an automated way to do this but “+12, enter , O, F12” will give you a 13 frames insert to start with and that’s if you use F10 and not F12 which superimposes to whatever duration the underlying clip is.
    Patrice
  • Adam Chesbrough
    March 29, 2011 at 5:42 pm
    I meant F10, thanks for the hint on the 1 extra frame, was wondering why there were 13…
