Activity › Forums › Adobe Premiere Pro › Default image still duration problem
  • Default image still duration problem
    Posted by David Hartman on January 17, 2015 at 10:08 pm
    Hello everyone, this might have been asked before but I’m not exactly sure what the problem is. I’m learning animation and i did a simple animation and rendered it out into png frames. The next step is to import the pictures into premiere to make a movie. I set the right sequence settings and changed the default image still duration from 5 seconds to 1 frame. But when i drag a image from the project file panel to the time line it is still 5 sec.
    Im on the latest version of creative cloud. Any ideas what i’m doing wrong?
    David
    David Hartman replied 11 years, 8 months ago 2 Members · 2 Replies
  • Ann Bens
    January 17, 2015 at 11:51 pm
    Changing still duration in the Pref. is done before import.
    However you can rightclick on the image in the Project Window and select Speed/Duration.
    Adobe Certified Expert Premiere Pro CC
    Adobe Community Professional
  • David Hartman
    January 18, 2015 at 3:46 am
    yep that what it was, i changed it after import thanks.
