Activity Forums Adobe Encore DVD default highlight
  • default highlight
    Posted by Sergio Barrozo on May 5, 2009 at 4:11 pm
    I have a menu with 4 text buttons. Each text has a highlight (a red line below the text).
    The four are distributed vertically one below the other.
    When I run a preview in Encore CS3, the highlight of the second text button appears as default. How can I force the first text highlight to appear by default?
    My layers in Photoshop are in the same order they appear in the menu. How can I do this?
    Joe Bowden replied 17 years, 4 months ago 2 Members · 1 Reply
  • Joe Bowden
    May 5, 2009 at 5:27 pm
    Look at your button numbers (select each button, then look at Button properties), and then look at your menu default button (select the menu, then look at Menu properties).
    Does your Default Button match the button you want highlighted?
    If not, either renumber your buttons (in Button properties), or reset your default button (in Menu properties).
