Activity Forums Avid Media Composer decomposing offline, relinking issues online…
  • decomposing offline, relinking issues online…
    Posted by John Collins on September 18, 2008 at 8:52 pm
    I’ve cut an offline project in composer, decomposed the sequence, and recaptured at a higher res for online on a different system(Adrenaline). My problem is though that none of my stills and movie files will relink-Avid just won’t find them even though I have all the original hi-res files. I point it to the right drive, or even search all available drives but nothing is found. Any suggestions?
    John Collins replied 18 years ago 3 Members · 4 Replies
  • Scott Cumbo
    September 18, 2008 at 10:50 pm
    you have to batch import that stuff.
    Scott Cumbo
    Editor
    Broadway Video, NYC
  • John Collins
    September 19, 2008 at 3:23 am
    Thanks Scott, not sure if I fully understand that, but I’ll give it a try.
  • Terence Curren
    September 19, 2008 at 6:04 am
    Select your sequence and select “Batch import” from one of the pulldown menus. (Not sure which one, it is automatic to me.)
    Then select “offline clips” (which is the default). Then you will get a dialog box showing the clips needed to import. You can select the clips and point them to the original files. If you have all the original file sin one place, and you select all of the clips, once you point the first one the rest will link up automatically. Now just set your media drive and resolution and away you go.
    Terence Curren
    http://www.alphadogs.tv
    http://www.digitalservicestation.com
    Burbank,Ca
  • John Collins
    September 19, 2008 at 8:34 pm
    That worked great, thanks
