Activity › Forums › Avid Media Composer › decomposing a sequence/up-ressing n Avid
  • decomposing a sequence/up-ressing n Avid
    Posted by Marc Martinez on February 8, 2008 at 6:05 pm
    Hello,
    I am a newbie to the world of working in hd/sd. I was inquiring as to the concept and purpose of “decomposing a sequence” and also the steps to decompose as well as the “upres” procedure in Avid.
    Marc
    Marc Martinez replied 18 years, 7 months ago 2 Members · 2 Replies
  • Scott Simmons
    February 11, 2008 at 9:16 pm
    Decomposing gives you a new sequence with offline media that has had all the clips trimmed to only include the media used in the edit + handles. If you’ve edited at low resolution you then recapture only the media you need at the online rez.
    Life is linear. Edit life.
  • Marc Martinez
    February 12, 2008 at 8:55 pm
    thanks Scott!!
    MM
