Activity Forums Adobe After Effects Expressions Decompose Script – Alterations
  • Decompose Script – Alterations
    Posted by Seb Neu on November 27, 2017 at 9:27 am
    Hi!
    I use the script “Decompose Text” (https://aescripts.com/decomposetext/) very frequently and it annoys me that:
    1) You have to delete the original layer manually
    2) Different font styles get lost
    I used it with the Option “Lines” and “Approx. Position”
    Would it also be generally possible that the line height (the gap between the lines) stays the same when decomposing?
    Thank you so much!!!
    Cheers,
    Sebastian
    Seb Neu replied 8 years, 9 months ago 1 Member · 0 Replies
  • 0 Replies
