Activity › Forums › Compression Techniques › Decoding x-rtvc1 RTP Streams ?
  • Decoding x-rtvc1 RTP Streams ?
    Posted by Christian Rheims on December 17, 2011 at 12:04 am
    Hello,
    Does anyone know how to decode the Video Streams from e.g. MSN Messenger 2011 ?
    The new Windows Live Messenger uses rtvc1 as Video Stream. The earlier versions used ml20 as stream.
    I managed to decode all I-Frames of such stream, but i cannot decode the B and P Frames.
    rtvc1 is a VC-1 based Codec, but it has some modifications for the RTP transmission.
    If i decode the I Frames, the Video runs too fast, because there are the B,P frames missing. The B,P frames are in my stream File, but the Decoder of ffmpeg only accepts the I Frames and skippes the B,P frames.
    I hope someone here is interested in decoding this streams, on roundup i´ll got responses from some users, but after a while they dropped the idea of decoding rtvc1 🙁
    Sorry for my bad english
    Greetz Chris
    Zeel Zeel replied 13 years, 10 months ago 2 Members · 2 Replies
  • Zeel Zeel
    November 19, 2012 at 10:54 am
    i can’t able to decode b,p and sp frame of x-rtvc-1 codec video file..
    so if u have any solution..
    plz give update on this Registered id..zeeltesting402@gmail.com
    regard
    zeelzeel
  • Zeel Zeel
    November 19, 2012 at 11:05 am
    when i try to play msn wireshark capture rtvc.vc1 file by removing all cc000000 and dc000000 then using ffmpeg it playing but we getting some error
    1>Luma scaling is not supported, expect wrong picture.
    2>Chroma scaling is not supported, expect wrong picture.
    and video playing so fast.
    so there is some specific decoder or player to play that file.
    note:={i think there is some mac player can able to play but i m not sure..}
    give reply
    on this id zeeltesting402@gmail.com
