Activity Forums Adobe After Effects Expressions Decoding Bounce Expression
  • Decoding Bounce Expression
    Posted by Ian Brown on February 10, 2022 at 3:47 pm
    Hello, can someone help me understand this expression at a high level, if you’ve the patience then by line would be helpful, but the last 3 lines (else statement) are most key
    amp = .1;
    freq = 2.0;
    decay = 2.0;
    n = 0;
    if (numKeys > 0){
    n = nearestKey(time).index;
    if (key(n).time > time){
    n--;
    if (n == 0){ t = 0;
    }else{
    t = time - key(n).time;
    if (n > 0 && t < 1){
    v = velocityAtTime(key(n).time - thisComp.frameDuration/10);
    value + v*amp*Math.sin(freq*t*2*Math.PI)/Math.exp(decay*t);
    }else{value}amp = .1;
    freq = 2.0;
    decay = 2.0;
    n = 0;
    if (numKeys > 0){
    n--;
    if (n == 0){ t = 0;
    }else{
    }else{value}
    Ian Brown replied 4 years, 7 months ago 2 Members · 2 Replies
  • Dan Ebberts
    February 10, 2022 at 7:16 pm
    It looks like you pasted it in twice, but in any case, the expression looks for the most recent, previous keyframe, calculates the velocity coming into that keyframe, and uses that velocity to calculate a decaying sine wave oscillation that gets added to the current value. The oscillation gets get off abruptly after 1 second.
  • Ian Brown
    February 10, 2022 at 10:13 pm
    Apologies, yes I did.
