Activity › Forums › Blackmagic Design › DecLink SDI AV out for FCP X?
  • DecLink SDI AV out for FCP X?
    Posted by Francois Driessen on May 28, 2013 at 8:05 pm
    Hi there. Might be missing something but I’m toying around with FCP X to give it a chance (*after the latest updates to get it pro-ready.)
    Somehow my AV out options through the Preferences only gives me one option:
    Blackmagic 720 x 486 @29.97
    My viewer does output to SDI but only in the above mentioned SD format. Anyone else running the DecLink SDI for HD output with FCPX?
    Francois
    FireTrigger Inc.
    https://firetrigger.com
    Members
    Bret Williams replied 13 years, 3 months ago 2 Members · 2 Replies
  • Francois Driessen
    May 28, 2013 at 8:28 pm
    OK> Solved. (To some extent)
    Noticed a subtext in the BM preferences in SYS PREFS that states:
    “Final Cut Pro X and startup video output will use this setting”
    Seems like FCP X does not see anything beyond what this is set to upon FCPX launch as an AV option. Annoyingly, it seems to only be able to set this upon startup of FCP X. So I can’t change AV output on a per “project” basis while FCPX is open… ?
    Any ideas?
    Francois
    FireTrigger Inc.
  • Bret Williams
    June 6, 2013 at 4:49 pm
    That is correct.
