Activity Forums Blackmagic Design DecklinkPlayback sample is flicking
  • DecklinkPlayback sample is flicking
    Posted by Hung Han on October 13, 2010 at 8:34 pm
    Do you know why the DecklinkPlayback sample is flicking? I tried with two “HD extreme 3” and both are flicking. The video flick once around 10 seconds (it shows a blue screen quickly and then back to normal).
    I’m using :
    * The DeckLink 7.9 drivers
    * DecklinkPlayback.exe from “Blackmagic DeckLink SDK 7.9”
    * HD Extreme 3
    If it is not SW problem, what kind of problems could it be?
    Regards,
    Hung
    Hung Han replied 15 years, 10 months ago 1 Member · 2 Replies
  • Hung Han
    October 14, 2010 at 1:08 pm
    Hi
    More details about the problem:
    * I’m playing a SD video
    * I’m using the SDI output “8 Y OUT”
    * The flick happens when i blend a image, it could be the “Blackmagic Design NTSC.bmp” file
    * After around 30 seconds it is showing a blue screen quickly and then back to normal
    Could someone knows what could it be?
    Regards,
    Hung
  • Hung Han
    October 15, 2010 at 7:26 pm
    Hi
    Problem solved, i was using the REF-IN and the signal was not tri-level
