Activity Forums Blackmagic Design DecklinkLink HD Extreme 3D+ – In The Dark Again
  • DecklinkLink HD Extreme 3D+ – In The Dark Again
    Posted by Richard Cruz on September 29, 2012 at 3:38 am
    I left my system alone for a very long time (over a year). Shortly after I started using it again, the hard drive failed on me so I got a new one and re-installed all my OS and software on that all over again
    I’m back where I started when I first put the system together – the Blackmagic Decklink HD Extreme 3D+ not working. Here’s the system details…
    Manufacturer – (Self Made)
    Processor: Intel i7 930 @ 2.80Ghz, 2794 Mhz (4 Cores) 8 Logical Processors
    Installed RAM: 16 GB Corsair DDR-3 CMZ8GX3M2A1600C9 4GB sticks
    Operating System: Windows 7 Ultimate, Service Pack 1, Version: 6.1.7601, Build 7601 (64-Bit Version)
    Motherboard: Intel DX58S02 64 Bit (PCI-Express Enabled) based on the X58 chipset and ICH10R south bridge
    BIOS Version: Intel Corp. SOX5820J.86A.0888.2012.0129.2203, 1/29/2012
    SMBIOS Version: 2.5
    VGA Card: nVidia Quadro 5000 (Driver Version: 9.18.13.593)
    RAID Adapter: ATTO: Express SAS R608-000 ESAS-R608-C00 (Driver Version:2.17)
    Video Capture Card: BlackMagic Design – “DeckLink HD Extreme 3D+” (Driver Version 9.6.4)>>> Card installed in slot 4 of MoBo.
    Video Signal Source:
    JVC BR-HD50 VCR (Mini-DV Tapes) Settings:
    Output via HDMI Port
    480i (Standard Definition) NTSC
    Note: Menu was recheched – it is set to output via the HDMI port
    Windows 7 Ultimate Situation:
    Executables:
    1. Blackmagic Streaming Server
    2. Blackmagic Software Updater
    3. Blackmagic CheckVersion
    All show up in the “System Configuration” App via MSconfig and the “Task Manager”
    Device Manager >>> Sound, Video and Game Controllers:
    1. Black Magic Audio
    2. Blackmagic Decklink WDM Streaming
    3. Blackmagic Driver
    All show up and are working properly
    Control Panel >>> Hardware and Sound >>> Blackmagic Design Control Panel:
    Set Input = HDMI Video and HDMI Audio
    User Account Control = Never Notify
    Note: Anti-Virus and Firewall were disabled while doing Blackmagic software install.
    Media Express Situation:
    Decklink Card Shows up under the “Device” menu with a check next to it.
    Edit >>>Preferences Menu >>> Project Video Format : HD 720p 60
    >>> Capture File Format : AVI 8-Bit YUV
    Note: I have switched the cable back and forth from both HDMI slots in rear of my PC but still no signal
    I did log in as Administrator when I did the install
    Richard Cruz replied 13 years, 11 months ago 2 Members · 3 Replies
  • Shaun Roemich
    October 3, 2012 at 5:39 am
    You have the deck listed as outputting NTSC 480I SD and Media Express listed as 720p, is that correct?
    Big Dog – Technical Director – Switcher
    Road Dog Media – Vancouver, BC Canada
    roaddogmedia@gmail.com
  • Richard Cruz
    October 4, 2012 at 5:43 am
    That 480i (Standard Defintion) was the format that the mini-DV tapes were recorded in.
    480i -> 704 x 480 pixels (60 interlaced frames/Sec) = 337,920 pixels total
    The last time I had this working right (when I previously posted on this forum and got the recommended settings from Joshua
    Director of Support at BlackmagicDesign), I switched them to those settings for the tape deck and same input settings from the Media Express App. and left them that way.
    Original posting:
    In The Dark with Blackmagic Design “Decklink HD Extreme 3D+” capture card – Sep 24, 2011 at 5:28:39 pm
    I forgot to mention that , I tried re-installing the legacy 7.9.5 Blackmagic Design drivers also (as recommended by Joshua) in the previous post but that trick didn’t get some “magic” happening this time around.
  • Richard Cruz
    October 27, 2012 at 2:40 pm
    Well, it’s been 3 weeks and still no reply from Blackmagic Design’s tech support team on my problem with this card.
    So Shelling out $950.00 for this card essentially got me:
    1. a non-working card/ software drivers
    2. a non-working tech support system
