Activity Forums Blackmagic Design decklinkHD pci-e dv field-order problem
  • decklinkHD pci-e dv field-order problem
    Posted by Oskar Vanden belt on April 11, 2007 at 10:42 am
    Hi there,
    Just bought this card, but have a big problem with the card, The card is playing my dv PAL sources incorrect. The fieldorder is reversed. Is there a workaround without rendering?
    Or better, a software fix?
    I hope it’s not an hardware design error, and can be fixed with a software patch.
    Can somebody, or people from decklink say something about this issue?
    tnx in advance,
    Oskar vanden Belt
    Amsterdam
    set:
    winxp32/sp2
    DeckLink 6.1 for Win XP
    ppro2, project SD DV PAL
    SD component out to monitor
    Luke Maslen replied 19 years, 4 months ago 5 Members · 5 Replies
  • Shane Chadder
    April 11, 2007 at 7:57 pm
    In NTSC I have to apply a motion effect to every DV clip and move it up 1 line to correct the problem and render it all. I’ve been working around it so long I’ll have to retrain all my editors if they actually fix it.
  • Slobodan Milivojevic
    April 13, 2007 at 3:37 pm
    This issue will be fixed in 6.2 version of driver (that’s what they promissed)!
  • Oskar Vanden belt
    April 13, 2007 at 4:59 pm
    would be very nice, so you think it’s just a software issue?
    thnx
    Oskar
  • Neil Sadwelkar
    April 14, 2007 at 6:28 pm
    Try going back to the 5.9.2 driver and see if that fixes it.
    Neil
    FCP Editor, Mumbai, India.
    Completely PAL.
  • Luke Maslen
    April 17, 2007 at 5:07 am
    Hi Oskar,
    The engineers tell me this is a software bug which will be fixed in the DeckLink 6.2 drivers which should be released soon after the engineers return from NAB, so hopefully that means in about 2 weeks.
    Regards,
    Luke Maslen
    Blackmagic Design
