Activity › Forums › Blackmagic Design › Decklink with Serious Magic Ultra
Posted by Melvin Chong on November 22, 2006 at 3:15 amThinking of using this combo for real-time keying preview.
Will this work ?
Melvin Chong replied 19 years, 9 months ago 2 Members · 5 Replies -
Deleted User
November 24, 2006 at 4:42 amHello,
We been trying to do the same, so far you can with ULTRA do a realtime test that the key looks okay for referance and lighting and keying setups. To test the screen you have to use the DV output from the camera as I do not think SDI, Component etc is supported.
Leo
Deleted User
November 27, 2006 at 4:49 pmHello,
Also I have noticed if I try and export using any of the Blackmagic codecs I cvan only export the audio and no video. I emailed Serious magic about this yesterday so hopefuly i will get a response.
Thank you,
Leo
Melvin Chong
November 29, 2006 at 11:37 amThanks for the reply.
Hopefully, I can use this as a poor man’s Hardware Ultimatte Keyer.
Deleted User
December 3, 2006 at 4:46 amHello,
I got reply from Serious Magic that the software used Directshow Video for WIndows and Quicktime Codec Library. They support Uncompressed AVi and Quictime along with DV encoder. So seems I can not use the Blackmagic codec to output to as I get is audio with no video which is strange. They said they have not tested with Blackmagic and suggested I try a codec called Huffyuv I am going to test this out later today.
WIth Ultra you will shoot to a tape or drive etc, load the clips into Ultra as they are or edit in your software then outout the clips. Import into Ultra, then do your key and output the files back to a video file then out these back into your editor.
You will not be able to get a realtime chromakeyer. Where you can key in realtime then record it back to tape or digital etc.
Leo
