Activity Forums Blackmagic Design Decklink Studio 2 has problem playing back 1080p/23.976 footage to flat panel via HDMI on MC6
  • Decklink Studio 2 has problem playing back 1080p/23.976 footage to flat panel via HDMI on MC6
    Posted by Knick Tran on September 20, 2012 at 4:38 am
    So I’ve been searching everywhere, and even contacted BMD Tech, and have yet to find an explanation, let alone an answer. So I’m thinking I should approach it this way.
    Can someone who’s on Media Composer or Symphony 6 and using a Decklink card w/ HDMI monitoring do this simple test for me. I’m assuming you have a flat panel hooked up to the HDMI port on the card. Here we go:
    1. Open up a 1080p/23.976 Avid project.
    2. AMA or import 1080p/23.976 footage.
    3. Be sure in the BMD Control Panel to select “Output HD 23.98p as HD 59.94i” (Otherwise you won’t see anything on the flat panel)
    4. Now play a long clip or a sequence, along w/ audio (10sec or more should be sufficient)
    Do you get an error message? Does audio drop in and out? Does playback on the flat panel or Source/Record monitor stutter?
    Can you please share your results? I’ll be posting this in other relevant forums so please excuse the double post.
    Thanks.
    Knick Tran replied 13 years, 11 months ago 1 Member · 0 Replies
  • 0 Replies
