Activity Forums Blackmagic Design DeckLink Studio 2 DVCPROHD Playback
  • DeckLink Studio 2 DVCPROHD Playback
    Posted by Andy Edwards on February 22, 2014 at 1:00 am
    Is there something special you have to do to get this card to playback DVCPROHD? Did a fresh install of this card to an editors Mac Pro Tower running Lion. Installed the drivers for Premiere CC, loaded up a project and it playbacks ProRes fine on the external monitor. Grab a DVCPROHD clip and place it in a Premiere Sequence, no external playback to the monitor. The same clip will play back in the Premiere Source monitor, but not the external. I work mainly with AJA based edit systems so any help with getting this BMD card up and running would be a great help.
    Andy Edwards
    Ericbowen replied 12 years, 6 months ago 2 Members · 5 Replies
  • Ericbowen
    February 24, 2014 at 5:14 pm
    What resolution is the DVCPro HD in? Do you lose playback if the DVCPro HD is in the same timeline as other media?
    Eric-ADK
    Tech Manager
    support@adkvideoediting.com
  • Andy Edwards
    February 26, 2014 at 2:55 am
    DVCPRO HD file is 1280×1080. Yes, you can load it into a timeline and it does not playback when mixed with other ProRes media.
    Andy Edwardss
  • Ericbowen
    February 27, 2014 at 9:56 pm
    Will it play on the program monitor if you don’t use the Blackmagic card for output?
    Eric-ADK
    Tech Manager
  • Andy Edwards
    March 6, 2014 at 6:54 pm
    Thanks for trying to trouble shoot this Eric.
    Not sure I get how you want me to test this. Change everything to software only in Premiere so it does not use the BMD card?
    Andy
  • Ericbowen
    March 11, 2014 at 10:21 pm
    Turn off transmit and see if that media will play in the program monitor.
    Eric-ADK
    Tech Manager
