Activity Forums Blackmagic Design DeckLink Stand-alone SDI Capture?
  • DeckLink Stand-alone SDI Capture?
    Posted by Espialidocious on February 5, 2007 at 9:03 am
    Suppose I had HD-SDI feeding a Decklink (not sure which is best, but DeckLink Extreme, say). I want to capture using a *stand-alone* application, not an NLE. Is this possible? Does such an application exist? Does one come bundled with the DeckLink? Is there a linux one? What formats can be captured by such an application? Just the ones supported by Decklink’s bundled codecs? Ideally, for the present, would like to capture to 4:2:2 8-bit, either AVI or QuickTime (but to be future-proof to expand to 10-bit 4* if required later). Or is there another more appropriate format? I understand the bandwidth and space issues. Many thanks if you can point an ambitious newbie in the right direction!
    Gordan Antic replied 19 years, 7 months ago 3 Members · 2 Replies
  • Kristian Lam
    February 5, 2007 at 10:25 pm
    If you’re going to be capturing HD-SDI, you’ll need a HD capable card such as the DeckLink HD Extreme. The DeckLink Extreme is an SD card and won’t do HD. If you want to capture 4:4:4 RGB HD, you’ll need a dual link HD-SDI product like the DeckLink HD Pro PCIe or Multibridge Extreme.
    We provide a standalone capture application called Blackmagic Deck Control. It’s currently Quicktime based on both Windows and Mac. You can capture to the Apple Uncompressed 4:2:2 codec (bundled with the drivers) as well as our Blackmagic RGB 4:4:4 codec. Unfortunately, we do not have Linux support.
    regards
    Kristian Lam
    Blackmagic Design
  • Gordan Antic
    February 8, 2007 at 10:21 pm
    hi,
    do you have a plan to add avi capture possibility to your deck control soon, to let’s say uncompressed or sony yuv (vegas) codec?
    gordan
