Activity Forums Blackmagic Design Decklink SP to consumer DVD Player?
  • Decklink SP to consumer DVD Player?
    Posted by Ponyboy on August 24, 2006 at 4:14 am
    Can Decklink SP be connected to a consumer DVD player in order to crash record onto an NLE? Thanks for your time.
    Steve Eisen replied 20 years ago 4 Members · 5 Replies
  • Kristian Lam
    August 24, 2006 at 5:45 am
    Yes, this is possible. You might need to convert the audio outputs of the DVD player to a suitable level for our card’s inputs.
    regards
    Kristian Lam
    Blackmagic Design
  • Ponyboy
    August 24, 2006 at 11:04 pm
    Thanks for your response Kristian. I have an Aphex audio balancer which accepts RCA input and spits out via XLR. I’m going to give this a try.
  • Rafael Amador
    August 25, 2006 at 1:36 pm
    Hi poniboy,
    Is just a an idea, but why don’t you try directly from the DVD driver. With MPEG Streamclip you can convert from the files on the disc direct to 10Bits UC or whatever. And you can mark in and out points.
    Salud
    Rafael
  • Ponyboy
    August 25, 2006 at 5:03 pm
    Rafael,
    Thanks for your suggestion. Actually, i have been using Mpegstreamclip to rip from DVDs. However, there are some instances where it will only rip a portion of the disc even though you select all the .vob files.
  • Steve Eisen
    August 30, 2006 at 12:27 am
    Use fix timecode breaks to see the whole file.
    Steve Eisen
    Eisen Video Productions
    Director-At-Large
    Chicago Final Cut Pro Users Group
