Activity Forums Blackmagic Design DECKLINK SP set up required for Firewire inputs
  • DECKLINK SP set up required for Firewire inputs
    Posted by John Archer on June 8, 2005 at 11:50 am
    DECKLINK SP and FIREWIRE input capture
    Normally using Blackmagic 8 bit PAL to capture from D9 format master tapes, I now have a large batch of MiniDV PAL tapes to capture and edit. I shall be using firewire to input from a camcorder or DV deck.Could someone advise on settings to use for capture, sequence and monitoring.Using Tiger and FCP5 with latest Decklink drivers.
    Thanks.
    John Archer
    Television Producer
    College of Medicine & Veterinary Medicine
    University of Edinburgh
    Scotland
    Kristian Lam replied 21 years, 2 months ago 2 Members · 1 Reply
  • Kristian Lam
    June 8, 2005 at 10:52 pm
    Hi John,
    Capture you clips using Apple’s Firewire easy setup. This is over firewire.
    After capturing, switch to our “Blackmagic PAL/NTSC – DV” easy setup, create a new sequence and drop your captured clips on that. This easy setup will also allow you to monitor off the DeckLink cards.
    Regards
    Kristian Lam
    Blackmagic Design
