Activity Forums Blackmagic Design DeckLink SP PCIe or DeckLink HD Extreme in Magma ExpressBox
  • DeckLink SP PCIe or DeckLink HD Extreme in Magma ExpressBox
    Posted by Dan Silber on July 3, 2007 at 12:34 pm
    I am trying to put together a portable hardware solution for my editing needs.
    I use Final Cut Pro 5.1.4 at the moment, and in terms of input/output, I basically need:
    – Capture of SD footage via analog inputs
    – Capture of HDV and DVCProHD footage via FireWire
    – Playback of HDV and DVCProHD footage on YUV SD (!) broadcast monitor
    – Mastering of SD and HD footage via SDI output to DigiBeta
    Does anyone know if the DeckLink SP (SD) can do the above, or do I need the next step up to HD (DeckLink HD Extreme). I will be outputting any HDV or DVCProHD footage directly via FireWire, so I have no need for HD-SDI i/o connections.
    Also, this card will be placed into a Magma ExpressBox and connected to by MacBook Pro via ExpressCard/34. As far as I know, that is a x1 PCIe slot, so the “DeckLink SP” should work fine. However, the “DeckLink HD Extreme” is a x4 PCIe card – but if I don’t make use of the full bandwith (no uncompressed HD) and thereby only use the card in a way that is x1 PCIe compliant, is it an option?
    Thank you in advance for your help!
    Dan Silber replied 19 years, 2 months ago 1 Member · 0 Replies
  • 0 Replies
