Activity Forums Apple Final Cut Pro Legacy Decklink SP card – ‘HARDWARE NOT FOUND’ but system sees it?
  • Decklink SP card – ‘HARDWARE NOT FOUND’ but system sees it?
    Posted by Robin Sa on January 27, 2007 at 3:43 pm
    OSX System Profiler and Expansion Slot utility report card is present and working at maximum speed.
    But Decklink panel in Sys Prefs all greyed out & BM speed test reports ‘Hardware not found’ !!!!
    New machine, clean install, only FCP5.1.2 and Compressor installed. Passes all HW tests.
    First installed new 5.9 driver, uninstalled, tried 5.7.3, repeated – no change.
    Reset firmware, zapped PRAM, repaired permissions – no change.
    Removed and reseated card, no other PCI cards installed (with hindsight should have tried another slot – will do that next week)
    Repeated all above – no change!
    What should I try next?
    Thanks in anticipation.
    MacPro 2.66, 3GB, OS 10.4.8, QT 7.1.3, FCP 5.1.2, Decklink SP PCIe (new, clean install)
    Slot 2
    Robin Sa replied 19 years, 7 months ago 1 Member · 0 Replies
  • 0 Replies
