Activity Forums Adobe Premiere Pro decklink sp and premiere pro 2
  • decklink sp and premiere pro 2
    Posted by Mark Bowes on May 20, 2007 at 7:45 pm
    HI I have a decklink SP card the PCI-33/66 version that I have just instaled in my new machine with Premiere Pro ( my old discreet edit* finaly died )
    I can capture perfectly in YUV from our J30 (PAL) but can not see the output on my component monitor ( cant even see the desktop on the component monitor )
    also i can not seem to get the output to work from the display settings of the computer , it shows it as being monitor 3 but nothing comes out ( i have 2 17″ lcds on the Graphics card )
    we have a intel D975XBX2 mother card with 4gb of on board ram, and a 500gig huge harddrive via scsi ( is this mother board ok for the decklink sp card?? ) is says on the blackmagic website that the D975XBX is ok??
    any ideas as to why i cant see the video
    regards
    Mark
    http://www.havpro.com
    Binh Le replied 19 years, 4 months ago 3 Members · 5 Replies
  • Blast1
    May 20, 2007 at 10:44 pm
    Make sure you have the correct output settings in both the decklink and display control panels
    >a 500gig huge harddrive via scsi< You only have one harddrive?
  • Mark Bowes
    May 21, 2007 at 6:47 am
    when you say
    “”Make sure you have the correct output settings in both the decklink and display control panels””
    the decklink is set toy SDI- y – r-y – b-y, there are not settings in display control panel except the screen size which is 720 x 576
    on the y out all I have is noise (like RF off air noise )
    the hard drive is a Huge systems 500gig
    any ideas
    regards
    mark
  • Blast1
    May 21, 2007 at 7:26 pm
    [mark bowes] “on the y out all I have is noise (like RF off air noise )”
    Are you using a extension cable or adapters on the output of the BOC
  • Mark Bowes
    May 22, 2007 at 5:36 am
    no just the cable supplied bncs in to the J30 and the output from the card in to my YUV monitor,
    but no luck
    regards mark
  • Binh Le
    May 24, 2007 at 8:51 am
    best way is you switch to Blackmagic forum
