Activity Forums Blackmagic Design DeckLink SP
  • DeckLink SP
    Posted by Sotvo17 on November 2, 2006 at 8:14 pm
    I’m about to start a Beta SP project and I’m looking at the DeckLink SP card for my PCI-X G5 and Final Cut . Can I use the SDI output on the card to go back out to a digibeta deck once I’m done? Also can I take the component output of a downconverted DV output from a Sony HDV camcorder into this card ? Any other method of taking HDV into the card?
    Kristian Lam replied 19 years, 10 months ago 2 Members · 1 Reply
  • Kristian Lam
    November 14, 2006 at 2:56 am
    Hello,
    [sotvo17] “Can I use the SDI output on the card to go back out to a digibeta deck once I’m done?”
    Yes you can.
    [sotvo17] “Also can I take the component output of a downconverted DV output from a Sony HDV camcorder into this card ?”
    If this is refering to the down converted output from the component output of the camera, then it’s a yes. However, you will have to put the audio outputs through a levels converter as the card expects a +4dB audio input.
    [sotvo17] “Any other method of taking HDV into the card?”
    Nope. You’ll have to go via your Mac’s firewire port.
    regards
    Kristian Lam
    Blackmagic Design
