Activity Forums Blackmagic Design Decklink – Sony LMD-1510W monitor Problem
  • Decklink – Sony LMD-1510W monitor Problem
    Posted by Ahmed Aborady on November 19, 2012 at 7:39 pm
    i Got Sony LMD-1510W for external video monitoring for Color Grading
    i connected it with SDI to DeckLink HD Extereme
    and installed Blackmagic desktop video
    actually i worked with same settings on Sony PVM-20L4 monitor and it just worked fine
    but now i get nothing on the monitor “NO SYNC” with finalcut or davinci
    Paul Provost replied 13 years, 9 months ago 4 Members · 4 Replies
  • Tom Sefton
    November 19, 2012 at 8:20 pm
    Do your project settings match the footage that you have on the timeline?
  • Ahmed Aborady
    November 19, 2012 at 8:25 pm
    YES the same project i used the other monitor and it was fine
  • Bob Zelin
    November 20, 2012 at 4:20 am
    please excuse my ignorance here, but does the LMD-1510W have an SDI input on it ? Are you connected via HDMI, or SDI ?
    I suggest that you take the CAV (Y Pb Pr) output of your Decklink HD Extreme, and go directly into the Y Pb Pr inputs of the LMD-1510W monitor. DO NOT TRUST the HDMI inputs. See if that works.
    Ultimately, you would have been better off with the wonderful
    Blackmagic SmartView HD 17″ Monitor, which would have given you none of these problems, and would have cost less money.
    Bob Zelin
  • Paul Provost
    November 20, 2012 at 4:31 am
    Sdi input optional card. There are hd and sd versions. Hd analogue component included.
    You might have the sd sdi card installed.
    http://www.4Kfinish.com | owner-colorist | Hollywood, CA
    http://www.facebook.com/4kFinish
