Activity Forums Blackmagic Design Decklink SDI audio output problem
  • Decklink SDI audio output problem
    Posted by Hkingy on September 19, 2006 at 10:23 pm
    I’m having a few issues on a brand new PC with a DL Extreme card, I can digitize clips using Decklink Deck Control through SDI (except I can’t hear audio coming in, see below). When I play back the clip on the PC, audio is present. However, when I use Decklink Deck Control and “Put” this clip back to tape, audio will not output to tape. While performing the “Put” function, I can see that the video insert button is lit up but none of the audio buttons are lit up, in essence, it’s just performing a video insert.
    Also, not sure if this is related but I can’t hear audio on the tape through SPDIF if I have the Black Video Output set to SDI out. However, when I disable it, I can hear audio.
    I’ve pretty much checked every setting/preference and still can’t figure it out. Hopefully someone can enlighten me on what else to try. In other words… Help!
    By the way, if I crash record to tape and play back from Decklink Deck Control, audio and video is recorded to tape. Here’s my system specs:
    HP xw4300 dual Pentium D 3.4GHz
    Windows XP
    4GB RAM
    Decklink Extreme
    Decklink Deck Control 5.6
    600GB SCSI RAID
    Sony Betacam SX DNW-A75
    Harlan
    Hkingy replied 19 years, 11 months ago 2 Members · 5 Replies
  • Luke Maslen
    September 20, 2006 at 4:07 am
    Hi Harlan,
    [hkingy] “When I play back the clip on the PC, audio is present.”
    Do you play back the clip using Blackmagic Deck Control or some other application?
    [hkingy] “However, when I use Decklink Deck Control and “Put” this clip back to tape, audio will not output to tape.”
    If you are using QuickTime 6.5.2 or older, open the QuickTime
  • Hkingy
    September 20, 2006 at 7:44 pm
    Hi Luke,
    I forgot to mention I’m using Quicktime 7.1. The settings in the QT control panel are as follows:
    Audio Tab
    Default Device=Decklink Audio Device
    Voice Playback=Decklink Audio Device
    I am able to hear audio out of the SPDIF monitors when I play back from Blackmagic Deck Control app, Quicktime Player, Premiere Pro 2.0 and Vegas 6.0. In fact, audio and video are outputting through SDI to my tape deck when I hit ‘play’ in the timeline of those applications. I haven’t tried printing to tape yet in the NLE applications.
    It’s when I do an auto insert to tape from Blackmagic Deck Control where the application isn’t telling the deck to record the audio channels. I have pretty much every preference in the PC pointing to Decklink output which is why this is so perplexing.
    Harlan
  • Hkingy
    September 22, 2006 at 6:10 pm
    Hi Luke, a few more things I’m noticing when using Blackmagic Deck Control. If you could let me know if these behaviors seem normal and whether this might be related to my audio problems:
    1. When I play back a clip captured with BM Deck Control on my Windows PC, there is no moving video in the left capture window. (On our new G5 with DL Extreme, I see moving video in the left window on play out).
    2. On the PC, the default audio monitoring preference is set to “Off While Recording”. I set it to “On” but it doesn’t change whether I can hear from the tape or not. After I hit OK, and I open that preference window again, it has reverted back to “Off While Recording” again. I can’t get it to stay on any other setting. (On the G5, there is no problem changing these settings and making them stick).
    3. On the PC, I use Ctrl K to “Capture Now”, there is no indicator to tell me that I am recording. On the G5, when I do Cmd K, there’s a pop up that indicates I’m recording plus a “Stop Capture” button. Is this the correct behavior for the PC version?
    4. On the PC, when I “Put” a clip to tape, I set an IN point for a 942 frame clip, my OUT point timecode displays some weird timecode like [00:33:>5] and [00:39:F2] and [00:40:D2] etc. The strange OUT time varies depending on where I set the IN point. However, it performs a correct length video insert edit to tape, just no audio.
    The PC is using BM Deck Control v5.6
    The Mac is using BM Deck Control v5.5.1
  • Luke Maslen
    September 25, 2006 at 2:10 am
    Hi Harlan,
    Can you please run a comparison test with Premiere Pro and let me know if you can output video and audio from Premiere Pro and record the audio to your deck? This will tell us whether the problem is specific to Deck Control or more general. Once I know the answer to this question, I shall answer your other questions about Deck Control.
    Regards,
    Luke Maslen
    Blackmagic Design
  • Hkingy
    September 25, 2006 at 6:45 pm
    Hi Luke,
    I just did an export to tape from Premiere Pro 2.0 and it worked great. Both audio and video was recorded to tape through SDI. Let me know if you think there’s an issue in my Deck Control app.
    Harlan
