Activity Forums Adobe Premiere Pro Decklink SDI 4K with Premiere Pro CC
  • Decklink SDI 4K with Premiere Pro CC
    Posted by Franco Cionini on May 25, 2018 at 6:37 pm
    Hi everybody! I’m having an issue with my Decklink SDI 4K while using Premiere CC 2018. I use it for color correction.
    I am trying to see my 4K clips within the timeline directely to the monitor I have connected SDI.
    My problem is that the monitor says NO SIGNAL. That kind of problem doesn’t happen with DaVinci tho.
    I have already tried to install all the drivers and followed all of the tutorials I could find regarding this issue.
    Anybody has any suggestions?
    Thank you very much!
    David Cherniack replied 8 years, 3 months ago 2 Members · 3 Replies
  • David Cherniack
    May 27, 2018 at 12:47 pm
    In Premiere’s Preferences/Playback/ make sure the Decklink is checked on and then you may have to play with its options to get the right “smaller than” or “larger than” setting. Otherwise there will be no signal. It’s kind of ridiculous that Blackmagic have you set that in their driver.
    David
    https://AllinOneFilms.com
  • Franco Cionini
    May 27, 2018 at 12:54 pm
    Hi David, thank you very much for your suggestion. I have checked and tried that already but it doesn’t seems to affect anything at all. Do you have any reccomendations on another 0 grade monitor I can use togheter with Premiere and 4K files?
    Thank you very much again!
  • David Cherniack
    May 27, 2018 at 1:06 pm
    Do your driver settings in Blackmagic Desktop Video match your desired output?
    David
