Activity › Forums › Blackmagic Design › decklink remote not working throgh router
  • decklink remote not working throgh router
    Posted by Sachin Agrawal on February 10, 2006 at 9:40 am
    hiii…
    i have G5 2.5 quad with decklink extreme its connected throgh video
    router but remote is not working .. when i am connect directly from the deck its working fine … i already chechk the cable, router and the deck…
    i din’t find whats the problemm or decklink remote its not wroking through router…
    plz give me a solution as soon as posiible
    its a great help if u give me a solution…
    Pl. Solve it.
    Mathias Hekton replied 18 years, 8 months ago 5 Members · 4 Replies
  • Shane Chadder
    February 10, 2006 at 5:04 pm
    Are you saying the 422 machine control works fine between the decklink and the deck, but not when you loop through the router? Is it the Blackmagic Videohub router?
  • Neil Sadwelkar
    February 11, 2006 at 4:47 am
    What router do you use?
    I have 4 decklink systems that work fine through a Network RS-422 router. In fact one of them even works as a DDR under external RS-422 control.
    It must be something about the cable pin-outs. The cable connecting the decklink to the router that is.
    Neil
  • Kristian Lam
    February 11, 2006 at 6:41 am
    Hi Sachin,
    It would help if you let us know what “router” you’re using?
    regards
    Kristian
    Blackmagic Design
  • Mathias Hekton
    January 17, 2008 at 1:35 pm
    Use a Keyspan USB to serial adapter and an old Avid serial to 9-pin remote cabel. Attach that to your router and change the port in the device control.
    Worked just fine with our router.
