Activity Forums Blackmagic Design Decklink & Red Rocket
  • Decklink & Red Rocket
    Posted by Nikolai Pigarev on November 1, 2010 at 6:41 pm
    I had it working with the AJA card but made a switch because of the RESOLVE.
    I am trying to monitor RGB 444 signal out of REDROCKET it goes out via dual link SDI that goes into the dual link sdi from the decklink and i was hoping it would come out of HDMI or 3G SDI but no luck so far.
    Is it possible? Are the inputs and outputs always active?
    P.S. I know HDMI has no RGB but i have added a hdlink in the mix. And a direct dual link red rocket to hdlink works now just wanted to work via decklink so as not to switch cables.
    Margus Voll replied 15 years, 10 months ago 2 Members · 3 Replies
  • Margus Voll
    November 2, 2010 at 2:40 pm
    HI.
    Asfar as i know DL card gives out stuff when you have supported software running ?
    RR wil just be as a hardware speedup for resolve with r3d.
    I’m not really sure how you would like to use DL ?
    Margus
    https://iconstudios.eu
  • Nikolai Pigarev
    November 2, 2010 at 2:59 pm
    The idea is like that. RR gives out RGB only via dual link sdi (or the breakout box that i dont have) I have a dreamcolor monitor tht can take in HDMI 10BIT but it need to be RGB so plan is use RR to DL to HL to DREAMCOLOR
  • Margus Voll
    November 3, 2010 at 3:26 pm
    I’m not sure that DL gives pass trough when no supported software is running.
    I would go with separate rgb to something converter maybe ?
    Margus
